Decklink SDI card Neo HD support.. at DVinfo.net
CineForm Software Showcase
Old March 12th, 2010, 04:23 AM   #1
Hi! I was looking for an option to record 10-bit 4:2:2 hd-sdi from a PMW-EX1. Is the DeckLink SDI the cheapest option to actually ingest 4:2:2 1080i HD-SDI with Cineform NeoHD ?
I am concerned about it actually being 10-bit internally, as the Intensity card advertised 10-bit internally but were only 8-bit..
Another concern is whether it actually allows HD recording. Some of the earlier HD-SDI cards were NTSC/PAL SD resolution only..
mishra.tv Productions
A Sydney-based group for dance movement-based video and film productions.
Anmol Mishra is offline   Reply With Quote
Old March 12th, 2010, 10:00 AM   #2
CTO, CineForm Inc.
Any of the Decklinks card will work for 10-bit HD.
Blackmagic Design: DeckLink Tech Specs
Old March 13th, 2010, 04:08 AM   #3
Hi David. My concern was if they were internally 10-bit. The BM Intensity cards had a 10-bit option when they came out. Turned out that the internal processing was only 8-bit.
I guess my question is :-
Can I use NeoHD + Decklink SDI to ingest 10-bit 4:2:2 via HD-SDI ? I was going to use the EX1 for this shoot..
Old March 13th, 2010, 10:35 AM   #4
CTO, CineForm Inc.
Yes, absolutely. Intensity is only a 1-lane PCI-e card, an issue for 10-bit, all the others are 4-lane or better.
Old March 13th, 2010, 05:30 PM   #5
You hit the problem on the head. If you click through the link you had above, ALL the Decklink cards say :-
Card type PCI Express 1 lane, compatible with 1,4,8 and 16 lane PCIe slots.
Thats for Decklink SDI, Optical Fibre and Studio.
Just wondering if Cineform has had these cards in for actual testing..
Old March 13th, 2010, 06:45 PM   #6
CTO, CineForm Inc.
We have a range of higher-end Decklink cards, they all work in 10-bit. We don't have the $295 Decklink. If you have doubts, get an AJA card.
Old March 14th, 2010, 12:30 PM   #7
The BM 1 lane cards don't work with the Asus P6T series motherboards at the moment either, just in case you're using one with an i7 (Blackmagic Design: Support Detail).
Geoff Gartside is offline   Reply
