Cineform and Display Cards - Page 2 at DVinfo.net
CineForm Software Showcase
Old May 3rd, 2010, 01:33 PM   #16
David, in your opinion is there a significant difference between the GeForce and Quadro cards from nVIDIA? I've read a fair amount about this and the most convincing information indicated that the Quadros do show fine detail in programs like Autocad more accurately, but I'm not sure how that relates to NLE performance and rendering.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old May 3rd, 2010, 02:47 PM   #17
CTO, CineForm Inc.
We only have Quadro cards here, so I can't compare.
Old May 3rd, 2010, 03:32 PM   #18
Originally Posted by Ben Winter View Post
If I bought two cheapo video cards, would I be able to output to two monitors from one card and the video overlay to an output on the second card?
Hi Ben,
I run a system with four displays with CS3/4/now 5 with two Quadro cards in the system...four heads.
TimK
Kolb Productions
Last edited by Tim Kolb; May 3rd, 2010 at 03:34 PM. Reason: trying to attach an image darnit...
Tim Kolb is offline   Reply With Quote
Old May 3rd, 2010, 05:00 PM   #19
Originally Posted by Tim Kolb View Post
Hi Ben,
Now thats a setup! Wow well done!
David Dwyer is offline   Reply With Quote
Old May 17th, 2010, 10:27 AM   #20
I've tried to find relevant posts on this forum regarding GPU/CUDA benefits with CF but I am getting confused. Is there a chance we could make a sticky out of this, or if Cineform's TechBlog could put together a guide?
I understand CF never required GPU to accelerate editing and its the codec that's designed to be efficient off the CPU.
I have no plans to leave Cineform's workflow, but I do want to know if I can benefit by upgrading my video card and taking advantage of CUDA. I find when I am effecting clips with Red Giant software or Boris software that it becomes very challenging to get a preview, sometimes Premiere even seems to crash. So I know upgrades are necessary, I'm just not sure where to put them. Is it better to get more RAM (I currently have 6GB), or is it better to get a new CPU (I currently have a dual-core)? Or should I upgrade my old ATI x1800 video card?
I figured it was the video card, but I keep reading posts as a CUDA/CS5 *versus* Cineform debate, as opposed to CUDA/CS5 *with* Cineform. Already agreeing to the benefits of CS5, is a video card upgrade justified?
Craig Irving is offline   Reply With Quote
Old May 18th, 2010, 09:26 AM   #21
Quadro vs Geforce
There seem to be two parts to GPU utilization here:
On playback, Cineform (that has removed interframe compression) does not use the GPU and Adobe native sequences use the Mercury playback engine and the GPU to decode the heavy interframe compression in AVCHD and MPEG2.
The decider could be in output: If you have a Quadro card with the elemental accelerator it would seem there would be a big speedup in encoding for disc ouptut in Encore, right?
[In subsequent research, there may be no Elemental Accelerator software for CS5 per this post:
http://www.elementaltechnologies.com...eative-suite-5
I hope Adobe has something up its sleve because their encoding with AME/MainConcept in CS4 seems so poorly multithreaded that it won't use more than two cores on my system where Cineform HDlink uses 100% of my quad.
Don Blish is offline   Reply
