Error in HDLink at DVinfo.net
CineForm Software Showcase
Old June 30th, 2010, 09:56 PM   #1
Error in HDLink
Hi
Any idea what causes this error
See attachment
Gil
Gil Reitsma is offline   Reply With Quote
Old July 1st, 2010, 05:11 AM   #2
re
I'm having the exact same issues with converting Panasonic's AG-HMC150 AVCHD files...!!
Miha Gapiha is offline   Reply With Quote
Old July 1st, 2010, 12:57 PM   #3
i thought I found a solution, but unfortunately not...
Support Center
Old July 1st, 2010, 01:45 PM   #4
Reproduced
I have reproduced this issue as well with HDV footage captured from a Sony HVR-V1U. I used both HDLink and Adobe CS5 to capture the footage off the tape and in both situations I get the error mentioned.
I was going to post a bug tonight when I got home, I'll still do that if it is necessary.
Ryan Gard is offline   Reply With Quote
Old July 2nd, 2010, 12:07 PM   #5
I got this reply from Cineform's support guy:
disable user account control in windows control panel and then download and install the 64-bit version of ac3filter from AC3Filter. during ac3filter installation, make sure to select both the 32-bit and 64-bit components.
then try converting your files again and it should work.
i'll try it later this night tho if it works
Old July 4th, 2010, 11:30 AM   #6
Fixed!
So I tried the fix in the previous post and it worked! All my footage converted fine.
