FCP mixing 1920 and 2k footage at DVinfo.net
CineForm Software Showcase
Old October 24th, 2010, 03:45 PM   #1
Anyone sucessfully found a way to mix the two resolutions without having to render?
I have a project shot on 7d/5d at 1920x1080, converted to cineform 1920x1080
Also shot on si2k 2048x1152.
I have not been able to figure out a way to mix the footage on the same timeline, without render bars, or sluggish playback on one of the resolutions. Trying to avoid having to re-render all the footage to a higher resolution. (don't think it is possible to transcode the 7d/5d to 2k res).
I have been given some suggestions, just seeing if anyone else has found a workaround.
help!
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply
