HDLINK Keeps encoding duplicate cuts at DVinfo.net
CineForm Software Showcase
Old January 29th, 2011, 11:04 AM   #1
I have cameras that use Flash cards; compact etc... and I still have HDV tapes that I need to back up.
When I use HDlink I get this on going conversion of cut after cut- it never ends. I check back and it has encoded the same segments 6 times.
I an using firewire and have HDlink set to split scene change.
All HD links are set to automatic. conversion hard drive WD Raptor Black
HP Z800
Quadro 4000
24 GB Memory
Dual Xeon 2.93 Hexcores
Windows 7 Pro 64
6TB on board storage
6TB Esata station Back up
Avid and Adobe or editing and effects programs
Ths happenned on ml last Dell 690 Dual xeon quadcore too
Any help please-
Dan Herrmann is offline   Reply With Quote
Old February 7th, 2011, 12:08 PM   #2
HDLINK continues to transcode the sameb cut over & over
I have had this problem for several years but see nothing on the forum about it.
when I transcode HDV tspe to cineform files The HDLink conitinues to produce endless numbers of cuts.
This is using the Scene Change check.
I use to use Adobe Cs4 to transcode into cineform and never had a problem.
will that feature be added to CS5?
I know Tape is fading and I use Compactt flash and Sd cards now, easy to back up with a BR 25 and to transcode to cineform for editing.
But this HDV question needs answered please.
Dan
