Vegas 10 and Cineform at DVinfo.net
CineForm Software Showcase
Old June 6th, 2011, 02:26 PM   #1
I read this on a previous post and just want to confirm that this is still the case with Vegas 10"
"So you can't color correct in Vegas as is, you have to use a calibrated external monitoring or add the video system to computer RGB conversion filter. FirstLight is correct on the desktop and for external monitoring".
This is quite a useful bit of information. If true this means I can use Firstlight to get an accurate preview on a calibrated monitor.
Should the monitor be calibatrated to a full range setting (0-255) or sRGB (16-235).
Mervin Langley is offline   Reply With Quote
Old June 6th, 2011, 02:32 PM   #2
CTO, CineForm Inc.
Re: Vegas 10 and Cineform
FirstLight uses 0-255. sRGB means something deferent than StudioRGB (which is 16-235.) "sRGB" is a graphics colorspace with is 0-255, not 16-235 (so potential confusing.)
Old June 6th, 2011, 06:35 PM   #3
Thank you! I will use first light for my color correction rather than Vegas then.
Old June 12th, 2011, 05:00 PM   #4
Mervin,
Yeah, I use vegas as well. It's nice that firstlight lets gives you an accurate rendition since FCP and Vegas both have unnecessary gamma issues.
Imagine this though: being able to color correct in ONLY firstlight. You don't even have to open your timeline to preview the changes as they fit in to the edit.
Read my idea for it here:
http://www.dvinfo.net/forum/cineform...cing-idea.html
What do you think about that?
Ben Hickson is offline   Reply
