Dual Core - Page 2 at DVinfo.net
CineForm Software Showcase
Old November 29th, 2005, 06:45 AM   #16
Hi,
Doesn't look like Costco carries it anymore. Here's a link to it at B&H. Its nice because it has 2 component inputs so I keep one connected to the computer and the other to the cable for the camera. Keep in mind that this monitor is not native 1080 but its scaling works pretty well and letting the Parhelia scale down to 720 to this monitor works great.
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Mick Guzauski
Mick Guzauski is offline   Reply With Quote
Old November 30th, 2005, 10:09 AM   #17
Thanks, Mick,
Funny, but just yesterday I was in Costco again and found the Samsung being displayed. Go figure.
My Parhelia is not here yet (most of the other components have arrived). Do you know if the Parhelia could scale to the native resolution of the Samsung, 1366x768?
Joe Clark
Joseph Clark is offline   Reply With Quote
Old November 30th, 2005, 10:50 AM   #18
Hi,
The Parhelia scales very well to the resolution of the monitor. I think the motion is smoother if you let the card scale down rather than have it output 1080 and let the monitor scale down.
Mick Guzauski
Old December 4th, 2005, 07:48 AM   #19
Dual corewise, I just got an Opteron 165 which is a 939 socket opteron. These are dual core and have 2MB cache for a lot less than the x2 4400 (same cache). Since it is a server cpu is tested more and can usually be overclocked better and with more stability according to a lot of the overclocking forums.
I also just got and evga 7800gt video card which comes with a component out cable and dual dvi ports and just ordered an Acer 24" lcd monitor which seems to be running about $800 right now. Worth looking into.
Canon C100, 5D3
Jeff Baker is offline   Reply With Quote
Old December 5th, 2005, 11:25 PM   #20
Parhelia Availability
I'm suddenly having trouble finding the PCI-Express version of the Parhelia. Anyone know where I can find it?
As for the nVidia, does it allow you to drive the DVI monitors and a component monitor at the same time? That's the draw of the Parhelia. Videoguys has a good deal on the nVidia card, but it won't do that.
Old December 6th, 2005, 12:28 PM   #21
I can report that the evga 7800gt nvida card works for component HDTV 1080i out to my direct view CRT HD TV and there is no delay while scrubbing the timeline in PremPro with Cineform.
I don't need the three monitor setup as yet so I have not tested that.
Canon C100, 5D3
Old December 6th, 2005, 11:57 PM   #22
Hi,
I got my Parhelia from Page Computers in L.A. Here's a link.
http://newsite.pagecomputers.com/sto...ct%5Fid=753989
Mick Guzauski
Old December 7th, 2005, 10:45 AM   #23
Now that I know where to get the Parhelia, I'd really like to know if the 7800gt can drive two analog monitors and the component HD preview output at the same time. If it can, with no blips in timeline playback, I might go that route.
My monitors are analog - 18" NEC LCDs with only VGA inputs.
Much apprecitated, Jeff and Mick.
Joe Clark
Old December 7th, 2005, 05:56 PM   #24
Will not work...even though the cards have three outputs,since they are only dual headed, you can only use 2 at the same time. The matrox card has 3 heads so you can with it.
Randy Donato is offline   Reply With Quote
Old December 8th, 2005, 04:24 PM   #25
Well I just captured 30 minutes of video from a sony hdr fx1 using my new opteron 165 dual core system. Not overclocked on this test so it is taking the 1.8ghz speeds an extra 14 minutes to convert to the intermediate.
Oh, the 14 minutes was the estimated time listed in the cineform conversion window - I did not clock what the actual time was but will on next test.
Not so great, but this is just my first test.
Originally Posted by Gary Harper
Any new updates about dual core, Premier Pro/Aspect performance?
Also, are any of the new dual core units hyperthreaded?
How about the Intel D 840 or 840 EE?
Intel D vs. AMD X2's??
Gary
Canon C100, 5D3
Old December 9th, 2005, 12:30 AM   #26
Parhelia
Thanks, I've ordered the Parhelia. One possible complication is that the video card I've ordered is a Sound Blaster X-Fi. I noted that one of its requirements is for a DirectX 9 compatible video card. I read that the Parhelia is not fully DirectX 9 compatible, so I might have to switch out the sound card.
Joe Clark
Old December 16th, 2005, 12:11 AM   #27
Joe Clark
So far, no incompatibilities have popped up, although the most daunting challenge in this experience is going to be the sound card. This X-Fi is massive in the scope of its capabilities. Makes the Premiere learning curve look like kindergarden.
I just got my activation number for AspectHD and have been enjoying capturing and editing with Premiere. This is a great combination.
Old December 17th, 2005, 12:42 AM   #28
Originally Posted by Mick Guzauski
Hi,
Mick Guzauski
Mick,
If you're still following the thread, I have the Parhelia and can't get it to display on the HDTV monitor. The two LCD's work fine, but nothing on the HDTV display. Do you remember having to do anything special to get the display? There's a plug-in on the Matrox disk for Premiere, but David Newman says it shouldn't even be necessary. My next stop is Matrox support, but they won't be answering it seems until next week. Thought you might have some thoughts, since your setup is so similar to mine.
Old December 25th, 2005, 04:09 AM   #29
Jeff,
Question 1: Is your HDTV set up as your second monitor then?
Question 2: Do all 7800s offer component out or are you refering to the DVI port?
Question 3: What motherboard are you running the Opteron on?
-- John.
John Hewat is offline   Reply With Quote
Old December 25th, 2005, 05:25 AM   #30
Originally Posted by John Hewat
Jeff,
-- John.
The evga 7800 has an external vivo breakout box that attaches to a port above the 2 DVI connectors. I am using this for my component monitoring as my hdtv does not have dvi port. Nividia recognizes this tv as a dual monitor setup.
I am running the evga nforce4 sli motherboard. Newegg and other dealers are offering a combo deal when you buy both of these products together.
Canon C100, 5D3
