Motion Stabilization + Cineform at DVinfo.net
CineForm Software Showcase
Old December 4th, 2005, 09:50 PM   #1
any one have any luck with using motion stabilization and HDV codec from cineform? i have had "unsucess" using FURNACE STABiLIZE PLUG-IN...
any other options that work and dont take years to render?
thanks
joel
Joel Corral is offline   Reply With Quote
Old December 6th, 2005, 12:30 PM   #2
How many frames are you trying to read ahead?
I have just got a dual core system installed and will be trying it soon, however this program was deadly slow using my old 3.2ee cpu on DV material so I would plan to only use it sparingly.
Canon C100, 5D3
Jeff Baker is offline   Reply With Quote
Old December 6th, 2005, 03:17 PM   #3
well i am using
average frames
step size = 0
filtering high
crop = colour
planning on importing the footage into a 720x480 16x9 project
and then zooming in on the footage to avoid crop markings.
joel
Old December 6th, 2005, 09:17 PM   #4
VirtualDub and the Deshaker plug work great, but they take forever and files have to be done one at a time.
Laurence Kingston is offline   Reply With Quote
Old December 6th, 2005, 10:35 PM   #5
virtualdub? i was unaware that this would be possible with such an app..
joel
Old December 7th, 2005, 09:43 PM   #6
Lance,
i haven't had any success with using deshaker... today i have been trying to stablize Cineform HDV footage.. what settings are you using?
thanks
joel
Old December 7th, 2005, 11:06 PM   #7
The first thing you need to do is to buy ConnectHD or AspectHD in order to be able to have access to the Cineform Codec in programs other than Vegas or Premier. You also need a recent version of Deshaker which has the HDV size settings as options. From there it is pretty much like working with DV only slower. On the plus side, the quality of the deshaken video is still really good. If you downrez to SD to write to DVD, you'll get great looking resolution that looks like it was done with a steadycam system. If I could just batch file the whole process I'd be pretty happy.
Old December 7th, 2005, 11:30 PM   #8
laurance,
i own aspectHD i am not clueless here, i just need some info on your settings that you use. i also have the latest deshaken plugin and also the latest of vdub...
thanks
joel
Old December 8th, 2005, 11:48 AM   #9
Is furnace working at all with your cineform footage or just slow?
Canon C100, 5D3
Old December 8th, 2005, 11:53 AM   #10
1st of all its exreamly slow...i have a pentium D dual core setup, pretty fast..
with 1 gig of ram... 800 gigs HDD...
in AE 6.5 it often crashes, and some frames won't even render... if there are any disolves, the next track will render black...the list really goes on and on..
joel
Old December 8th, 2005, 12:01 PM   #11
I am just finishing up a reinstall of my system from scratch on a dual core opteron 165 system today. As soon as I get the furnace plugin installed I will run it on some handheld footage of 5 sec or so in length and post results.
Canon C100, 5D3
Old December 8th, 2005, 07:11 PM   #12
great thanks alot...
joel
