problem with preview video with version 5... at DVinfo.net
CineForm Software Showcase
Old May 15th, 2007, 02:18 PM   #1
ok obviously have the new aspect version 5. when I create a new project now I cant view the video in either the left or right preview panes in pp2 from my captures with hd link. no problems ever with version 4 with this. I hit play and nothing happens. anyone else having this problem?
ps. same thing happens with older projects captured and edited with version 4. gonna try reinstalling 5 to see if it had a bug during install
Mark Leonard is offline   Reply With Quote
Old May 15th, 2007, 02:38 PM   #2
ok upgraded from build 81 to 82 and that seemed to fix the problem. I just bought it and my link took me to build 81 so make sure you guys go back and update to build 82. now I've captured several tapes with build 81, should I go back and re-capture with build 82?
Old May 15th, 2007, 02:54 PM   #3
CTO, CineForm Inc.
The codec is the same between build 81 and 82, no re-capture needed.
Old May 15th, 2007, 03:15 PM   #4
I had the same problem in build 81. Build 82 solved the issue.
Frank Pitsikalis is offline   Reply With Quote
Old May 15th, 2007, 03:29 PM   #5
Originally Posted by Mark Leonard View Post
... so make sure you guys go back and update to build 82.
Mark, thanks for noticing and reporting this. Yep, I was pointing to the previous (B81) build - now fixed.
David Taylor is offline   Reply
