CF5 doesn't seem to work with AE-CS3 - Page 3 at DVinfo.net
CineForm Software Showcase
Old August 25th, 2007, 07:03 AM   #31
I'm a NEO user, tried all of this (removing files, running .reg file) and I still can't import into AE CS3. I appreciate that this isn't just cineform's fault, but a fix is obviously needed.
Kris Bird is offline   Reply With Quote
Old August 29th, 2007, 03:26 AM   #32
Is the latest build supposed to fix the AE CS3 problems? Because right now it just crashes my AE CS3 whenever I import a CineForm AVI.
Ferdi Willemse is offline   Reply With Quote
Old August 29th, 2007, 09:32 AM   #33
CTO, CineForm Inc.
The latest build fixes all of this, if it doesn't you will likely have an install issue, and need to contact support.
Old August 29th, 2007, 10:58 AM   #34
Whith the new CF build 90 I don't have that issue anymore. Also I have to mention that I reinstalled the AEcs3 cause with the latelest update from last week of AE my Cf avi files were crashing. At that time I was using the 89 build so I don't know if I update AE again It will have the same problem again.
I hope not. But try reinstalling.
Jose Ortiz is offline   Reply With Quote
Old August 29th, 2007, 01:40 PM   #35
Thanks for the fix, CF! I'll reinstall tomorrow.
Old August 31st, 2007, 10:43 AM   #36
I post also here :
- last week we captured test shots with Neo HdLink NEOHDv305b135-070801
- today we have installed AE CS3 (should be the latest release)
and then we have uninstalled the previous CF version and installed the new NEOHDv310b137-070827
when we try to import one of the avi captured last week, AE crashes saying there is a problem with "cfhd.dll" ??
any solution for us to keep on doing our tests ???
Denis
Denis Cadamuro is offline   Reply With Quote
Old August 31st, 2007, 11:00 AM   #37
CTO, CineForm Inc.
Talk to support as AE should not be using CFHD.dll, that suggests you did not get im-CFHD_File_Import.prm installed in C:\Program Files\Adobe\Common\Plug-ins\CS3\MediaCore -- please check that and report to the support team.
Old August 31st, 2007, 11:16 AM   #38
David, Thks for your super fast answer
yes this file is not present in ...Common.. directory
okay, I contact the support now
Old August 31st, 2007, 12:20 PM   #39
CTO, CineForm Inc.
While that file missing likely indicates you registry installer path for CS3 is wrong or missing, you can install that particular files manually as it is also located in the Premiere plug-in founder located here : C:\Program Files\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\CineForm
