Suggestion: dual balanced audio inputs THREADED at DVinfo.net
Convergent Design Odyssey
Old October 13th, 2009, 10:23 AM   #1
This may have been suggested before but looking at the pix in the new manual at the single 3.5 mm consumer level audio imput gave me heartburn.
Surely on a 3000 dollar piece of equipment CD could use a threaded jack so the signal doesn't get interrupted by jiggling wires that will ultimately compromise the physical integrity of the jack itself. Also, in these days of high quality stereo mics two balanced inputs would be more appropriate than just one.
David
AllinOneFilms.com
David Cherniack is offline   Reply With Quote
Old October 13th, 2009, 10:32 AM   #2
Hi David:
FYI, the Flash XDR gives you precisely this solution. but it's more money.
Mark Job is offline   Reply With Quote
Old October 13th, 2009, 10:36 AM   #3
It's also a much larger piece of equipment. Nothing I would consider.
Old October 13th, 2009, 12:45 PM   #4
Convergent Design
Hi David-
We agree. Threaded audio jacks would be preferred as well as dual balanced inputs.
We added the analog audio as a last minute update after NAB. So, we did our best in the limited time to meet our production schedule.
One immediate workaround would be to tie wrap the audio cable to the HD/SD-SDI cable. I realize this is not ideal, but one it's one possible solution.
Best-
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old October 13th, 2009, 12:53 PM   #5
Hi Mike,
Good to hear that locking jacks are contemplated for the future. Shouldn't be too hard to replace the one that's there. Making room for a second may be a bit of a squeeze, though.
If one is using the unlocked HDMI inputs it might not be such a good idea to tie wrap/Velcro wrap to it.
David
AllinOneFilms.com
Old October 13th, 2009, 01:07 PM   #6
When looking at which recorder to buy, I considered both XDR and nano Flash. I too was not happy with the size of the XDR. I considered not only the audio connectors but the quality, flexibility and capability of the audio as well. Because of this, I could not consider the nano Flash.
The XDR has "no compromise" audio all around, and that's ONE of the reasons I went with the XDR.
The XDR is actually smaller than I thought it would be, it's not "big" at all. It balances my rig out perfectly for shoulder shooting. Couldn't be happier with it.
Aaron Newsome is offline   Reply With Quote
Old October 13th, 2009, 01:18 PM   #7
Hi David:
The audio quality of the XDR is amazingly good. The XDR holds Four CF cards too, so there's more recording time possible. The XDR has an RS-422 and HDV interface, so its future as a VTR replacement that bridges the gap between VTR capture and file based import looks quite promissing.
Old October 13th, 2009, 01:28 PM   #8
Guys, I have no doubts as to the advantages of the XDR. Size, however, is paramount for me.
I can't consider it.
David
AllinOneFilms.com
Old October 13th, 2009, 02:48 PM   #9
Dear David,
The nanoFlash can accept stereo unbalanced consumer line-level inputs.
What is not immediately obvious, is that the nanoFlash can take the "Tape Out" of most mixers, using a simple low cost audio cable. This "Tape Out" is typically, stereo unbalanced, consumer line-level, output.
By using a mixer, one can use the phantom power capabilities of the mixer and, depending on the mixer, the world class microphone preamplifiers. Thus, multiple world class balanced microphones can be feed into the mixer first, then the "Tape Out" feeds the nanoFlash.
The preamps in the nanoFlash are good, but not as good as the world class preamps in the Flash XDR or a great external mixer.
The nanoFlash records 24-bit audio and works very well when feed a "Tape Out" signal.
Please note that it may be desirable to attenuate the "Tape Out" signal. We recommend testing of the mixer and nanoFlash setup.
From my Sound Devices 744t or 302, I prefer to attenuate the "Tape Out" signal some to achieve the best results.
Dan Keaton
Augusta Georgia
Old October 13th, 2009, 03:08 PM   #10
Thanks, Dan.
The Sound Devices 744 is one of the nicest engineered pieces of gear I've ever come across. I used one to record double system on a documentary in Northern India. However double system does add some annoying extra steps in post.
I've been seriously thinking of picking up a small camera - either a SLR or a something like a Pany HMC40 to go with a Nanoflash to do some inobtrusive shooting. That would mean going into the Nano via HDMI and using the remote switch for stop/start. If I go with the HMC40 it does have an XLR option. If I go with a SLR it means going from a decent stereo mic into the 3.5mm unbalanced. With an RF receiver and the Nano I don't want to add another item like a mixer to the setup.
David
AllinOneFilms.com
