EX1 Recording Questions - Page 2 at DVinfo.net
Convergent Design Odyssey
Old May 26th, 2010, 01:31 PM   #16
That is the current firmware
FYI see link below
Downloads | Convergent Design | Professional Video Recorders and Converters
Luben Izov is offline   Reply With Quote
Old May 27th, 2010, 12:45 AM   #17
Originally Posted by Luben Izov View Post
Dear Adam and Steve,
I believe you have miss understood the Loop Recording. Loop Recording, according to the NF Manual is overwriting the files without formating the card. Please see below:
From NF Manual
Loop Record: In this mode, the nanoFlash will record continuously to card 1, then to card 2,
then back to card 1 (overwriting previous contents), then back to card 2 (again overwriting previous
contents), etc til stopped. The current card is completely erased before any files are written. Do not
use Loop Record mode unless willing to have older material overwritten by newer material in a
record session. “Loop Record” will appear on the screen in this mode. (ver1.5.31)"
Okay, so my ? is can card #1 be removed from the nF and copied to a computer while card #2 is being written to, and so on? And if I do this, will I get a contiguous set of files w/o breaks?
So for example, I have two cards and I'm recording 30mins/card. If can I record two hours uniterrupted by swapping out cards. Sounds extreme, but I'm working a documentary that can benefit from long record times, and the nature of the material means that I don't want to be forced to stop recording.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old May 27th, 2010, 03:49 PM   #18
Hi Peter,
May I suggest you back down your bitrate to 50Mbit on record LongGOP (XDCAM) and not iFrame. You will still get 4:2:2 color. Your footage will still meet most broadcast requirements at 50Mbit/4:2:2.
-Andrew
Old May 27th, 2010, 05:32 PM   #19
Simply, you can not do that! Hot swaping is not permited as of yet.
No, you would crash your NF unit and most likely damage your CF Card/s
Get yourself a large cards for long recordings and hope CD would be up with the new "hot swaping" option in the new firmware.
Hope this helps you
Luben
Old May 27th, 2010, 07:05 PM   #20
Dan or Mike, can you guys confirm that hot-swapping is not available.
Old May 27th, 2010, 07:12 PM   #21
Dear Steve,
Yes, Hot Swapping of cards is not available.
One can insert or remove a CompactFlash card while the nanoFlash is powered on, provided that the nanoFlash is not recording or playing back.
Thus, if one is recording or playing back, we do not support the inserting or removal of a CompactFlash card at this time.
Quite a lot of code has been added to the nanoFlash, as part of a project to allow for Hot Swapping. But this project is not yet complete.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
