Nanoflash as a pool recorder at DVinfo.net
Convergent Design Odyssey
Old December 2nd, 2010, 01:44 PM   #1
Hi folks,
I'm interested in using the Nanoflash as a compact and cost-effective SDI pool recorder.
Has anyone used them in this scenario?
Can they be set to record regardless of feed interruptions etc? (ie a deck such as an HVR 1500 will just keep recording black if a feed is interrupted - essential in an environment where one doesn't control everything).
Can you see the timecode in the window during recording, and is it large enough to log from? (Obviously they'd be plugged in to monitors too).
I'm renting one for a couple of days to test it for myself, but I'd really appreciate it if anyone has an experience themselves that they could share.
Tape decks are big, heavy, expensive and costly in excess baggage, but producers like them, surely there's got to be a bullet-proof and cost-effective tapeless solution!
Cheers,
James
James Vernon is offline   Reply With Quote
Old December 2nd, 2010, 02:05 PM   #2
Dear James,
If the HD-SDI (or SD-SDI) feed is interrupted, then the nanoFlash will close the current file.
Then when the feed returns, the nanoFlash will start recording again automatically.
Yes, you can see the timecode in the nanoFlashes LCD at all times, while recording or not. Yes, it is readable.
I think it will work fine for you.
With two of the new 128 GB cards, expected to be shipping in less than three weeks, you can record broadcast quality, uninterrupted, for approximately 10 hours and 40 minutes.
Dan Keaton
Augusta Georgia
Old December 2nd, 2010, 02:38 PM   #3
Thanks for your fast response Dan.
It sounds very interesting indeed. I look forward to testing it myself. The feeds (I'll be recording 2 of them - double the reason to have a compact solution) will be SD-SDI.
With the new firmware will the nanoflash automatically switch between cards seamlessly when one fills up? (I ask because they tend to rent with 32GB cards over here in the UK).
I'd still love to hear from anyone with real-world experience of using the Nanoflash in an ENG pool-feed type scenario if you're out there!
Cheers,
James
Old December 2nd, 2010, 02:48 PM   #4
Dear James,
We have automatically, and seamlessly switched from one card to the next since day one.
With our current Public Beta, we support Hot Swapping.
In SD, you can record in IMX, 30, 40 or 50 Mbps.
Also, if desired, you can record a pre-rendered MPG file for a SD DVD, in 3, 5, 6, 7, 8 or 9 Mbps.
I recomment the IMX 30, 40 or 50 Mbps if you are going to edit the files.
Dan Keaton
Augusta Georgia
Old December 2nd, 2010, 04:43 PM   #5
Great, thanks.
I'll post back once I've played around with one.
James
