menu setting issue at DVinfo.net
Convergent Design Odyssey
Old February 10th, 2011, 06:36 AM   #1
menu setting issue
I have a strange problem with the Nano:
Everything works perfectly, until I create a "MENUxx.stg"
It no longer takes any recording command, whatever the trigger method chosen .
However, all parameters are well preserved and stored in memory, and it still recognizes the time code from my EX3
As soon as I reformat the CompactFlash, all comes back in order, and I can record on Nano, but of course, }CFG{ folder has disappeared.
on the other hand, if I created a "setting.txt" I have the same kind of problems!
I tried to format the cards again, reinstall the firmware, change the record method .... it's useless.
I'm on 1.6.248 (same problem with 1.6.245)
EX3, SDI
Cards: Delkin 64GB 450x UDMA6, Transcend 64GB 400x UDMA: same problem on both.
Didier
Didier Perrichon is offline   Reply With Quote
Old February 10th, 2011, 07:37 AM   #2
Dear Dieder,
Please use a separate CompactFlash card for your Settings.txt or Menuxx.stg files.
Once you have either of these files on a card, you can not subsequently record to the card, unless the card is reformatted again.
Dan Keaton
Augusta Georgia
Old February 10th, 2011, 09:28 AM   #3
Ok, thanks
Now I understand how it works...
... but sometimes, it would be very useful and much faster to use only one card !
Old February 10th, 2011, 10:03 AM   #4
Dear Dieder,
Yes, I understand and we will take it under consideration.
We recommend, as a standard practice (in fact, we insist on it), that one formats the cards in the nanoFlash prior to recording. This ensures that the nanoFlash can operate up to its potential.
Thus, just deleting some files and leaving these menu or settings files, then using the card without formatting it, is a problem, as this leaves a fragmented file system.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
