End Credits in After Effects at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old August 3rd, 2007, 10:29 AM   #1
I want to make the scrolling up credits like at the end of movies. How exactly do you make them? Thanks!
Kyle Kauss is offline   Reply With Quote
Old August 3rd, 2007, 10:44 AM   #2
Are you sold on AE? I guess one way would be to just create a text file then create a camera and scroll it down (or move the text up with a start and end keyframe). That's a pretty ghetto way, but it would work. I'd recommend using FCP or the comparable. It's a lot easier and the timing is simplistic.
Alex Sprinkle is offline   Reply With Quote
Old August 4th, 2007, 10:31 AM   #3
If you have illustrator (or photoshop) place all the text into a file, if your using illustrator make sure you adjust the page size to fit around the text. Import the file into AE and animate (motion). I do this in Premiere and it works great and if you find a typo, or want to add to the credits, simply edit the original ill file.
Jon
Jon Jaschob is offline   Reply With Quote
Old August 17th, 2007, 08:18 AM   #4
Don`t forget to add a little motion blur to make motion more smooth, it really makes a world of difference. And do not use too thin fonts.
Jiri Fiala is offline   Reply With Quote
Old August 20th, 2007, 10:01 AM   #5
What NLE are you working in? Premiere allows you to add animated titles. If you need to work in AE, create a text layer, insert your text, and animate it using y position.
Dale Stoltzfus is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
