Can AE CS3 import/export m2t or mxf? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 4th, 2008, 09:27 AM   #1
As above. Looking to work between AE CS3 and Vegas 8.0. I cant find the info in the specs.. Thks!
Old January 4th, 2008, 11:25 AM   #2
Adobe Systems
Yes, After Effects CS3 can import .m2t files.
M2T is listed in the "Supported import formats" section of After Effects CS3 Help on the Web. Also, just to be sure, I just imported a .m2t file and it worked fine.
Todd Kopriva, Adobe Systems Incorporated
After Effects quality engineer
Todd Kopriva is offline   Reply With Quote
Old January 4th, 2008, 07:17 PM   #3
Wonderful. Thank u Todd! So I noticed AE cannot output m2t. So how do I work the output into an m2t project in Vegas 8? I read somewhere that YUV is a good choice as the compression is sort of lossless in a certain way.
Old January 4th, 2008, 09:03 PM   #4
Adobe Systems
I'm not sure about Vegas, but folks tend to recommend Animation codec.
I haven't ever used Vegas, so I'm going by what I know for After Effects exporting files to other NLEs. People have good luck rendering in After Effects and exporting with the Animation codec (quality set to highest) to a QuickTime container. At the highest quality setting, Animation is lossless.
Old January 14th, 2008, 09:59 PM   #5
I'm working between vegas 7 and AE 7 rendering uncompressed avi from vegas, applying effects in AE, export to png sequence and import that to vegas. Problem is I can't get the colour space to match so the png's in vegas look darker compared to the original after that process and I have to fiddle with colour correction to match them up. However AE doesn't seem to change the colour space when importing and exporting png's...
So is there a way to render a png sequence from vegas? There's a script for rendering an image sequence but it's not frame accurate, you have to set the interval and it doesn't seem to be possible to set the interval to get every frame. The smallest interval of .01 is too small and generates an error, the next largest interval is .02 but that skips frames. Frustrating!
Or is there a way to get the AE's colour space to match vegas for avi's? I haven't been able to figure it out, colour match rgb in the project settings is closer but not really a match, none of them are.
Andy Gordon is offline   Reply With Quote
Old January 15th, 2008, 10:58 AM   #6
sounds a little tough to me! I just bought AE and am just trying it out. I think I will work to import avi from Vegas 8 and finish up in AE since I have Magic Bullet Looks to go along for CC. Antoher step back to Vegas would be quite killer.
Sean Seah is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
