Importing a Ppro CS3 project file into AE CS3 issue at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old April 12th, 2008, 11:37 AM   #1
I did it last week as a test and chose the sequence I wanted to import, then when I put the sequence on the comp in AE it showed each individual clip cropped on individual layers to how it was edited in Premiere. I tried again today and its just importing as one solid, one layer, that I can't edit where videos go....any idea why?
Cinematography Site
Nathan Quattrini is offline   Reply With Quote
Old April 12th, 2008, 01:54 PM   #2
ok after a bit of a battle with it and trying every possible thing, I relearned you can go in premiere and straight copy the sequence then paste it in AE allowing you to move things around etc. Whew. Hope my blunder helps someone else in need.
Cinematography Site
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
