Turing a static shot to handheld? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 15th, 2009, 01:40 AM   #1
I would like to make a shot that was filmed on a tripod, look like it is hand held. I would like a subtle movement, not Bourne trilogy style. How would this be done?
Joe Riggs is offline   Reply With Quote
Old May 15th, 2009, 05:05 AM   #2
Here you go... VIDEO COPILOT | After Effects Tutorials & Post Production Tools
the examples are a little extreme... but you can tune it the way you want it.....
Old May 15th, 2009, 09:46 AM   #3
The easiest way to accomplish this is in After Effects with a wiggle expression attached to the position. However, you'll have to make sure you have enough 'frame' to have the shot move a little, so you'll need to scale the shot up a bit. 10% or more should work fine depending on your wiggle parameters.
I'm not in front of AE at the moment so I can't give you the exact steps to accomplish this, but you should be able to find something about the wiggle expression on the Net.
Reel Inspirations - www.reelinspirations.com
Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
James Huenergardt is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
