What can I do to make this background better? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 15th, 2010, 11:25 AM   #1
I am working on having an animated background for (audio) radio interviews and this is what I have so far:
Yfrog - testbackground
I am using AE, and am looking for suggestions for making it look more professional, and maybe some animation ideas for the fractal noise background.
Any ideas? Feel free to criticize.
Natan Pakman is offline   Reply With Quote
Old January 17th, 2010, 06:53 PM   #2
Add Depth
Right now it's only two layers, that background (blue and busy) and the foreground images.
Try adding some layers between the two, possibly static or moving vertical lines so you don't fully cover up the background. What you'll then find is that you can go with a less busy background and add more depth through simple layering. The more layers you add, the simpler each particular element can be.
Depending on what you want the viewer to focus on and how long they have to absorb it all, should also determine just how complex you want it to be.
Paul E. Coleman is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
