AE 3D text to premiere at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old April 5th, 2011, 11:14 PM   #1
What is the best way for me to export some 3D text preset or comp from After effects cs5 to Premiere CS5 where I can apply it to a scene in Premiere?
Victor Boyko is offline   Reply With Quote
Old April 19th, 2011, 07:59 AM   #2
Re: AE 3D text to premiere
The best way would be exporting it in lossless with alpha, which preserves your alpha channels and lets you drop in on any background you like. It it a big file though, and premiere might have trouble playing it back while your editing. If you need to time it with music or you need to do any type of adjustments in premiere, I would suggest exporting it at draft quality, so that you can play it back, and then export it in full HQ and just replace the footage after you're done with your work in ppro.
Cheers!
Vlady Gerasimov is offline   Reply With Quote
Old April 26th, 2011, 07:47 PM   #3
You could also use dynamic link, but I would only recommend that route if you have a powerful editing system.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply With Quote
Old May 17th, 2011, 04:50 PM   #4
thanks this helps
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
