Sliding square video mask/effect at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 24th, 2013, 07:27 PM   #1
Does anyone recognize the sliding square mask/effect used in the intro of this video? How can I get a similar effect?
Paul Manoian
Detroit Photographer
Paul Manoian is offline   Reply With Quote
Old January 25th, 2013, 04:29 AM   #2
Re: Sliding square video mask/effect
These are pretty complicated to make usually. This one probably came in a stock pack of them where it's just a matter of inserting the video clips you want to use and changing the text.
I can't seem to find any right now of the sort I used to see at my old work years ago. I suspect the squillions of one-offs and templates people sell on the net now has killed that market
Murray Christian is offline   Reply With Quote
Old January 27th, 2013, 09:29 PM   #3
Thanks. I haven't been able to find any similar video masks like this that I can use as an intro.
Paul Manoian
Old January 28th, 2013, 06:56 AM   #4
I'm not sure about ready-made masks, but it looks like a simple PSD file (the black lines), where the boxes are animated to slide over the video. Pretty basic - no need for masks.
Old January 31st, 2013, 03:46 PM   #5
For an intro that is going to be used multiple times with small variations to titles, it would not be too terrible an undertaking. That's half a day's work for 13 seconds of high impact video that you will use over and over.
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old January 31st, 2013, 04:59 PM   #6
Since I use after effects/photoshop for everything this would be pretty easy but time consuming.
Build the object in PS - and import the layers independently, then I would start building Null object groups and individually start animating the slides/opacity/text and group them together differently and do a variety of animation rates. Yeah its time consuming, but if you build it the right way, it will be reuseable and if there is a good null hierarchy built you can easily build in variation.
If you are looking for pre-canned versions of this stuff, good places to check out are sites like VideoHive.
Automotive Multimedia
Justin Molush is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
