GLidetrack owners, what tripod are you using? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
Old May 28th, 2009, 01:52 PM   #1
Hi All,
I'm buying a glide track and need to get an idea about the tripods people are using... please feel free to share.
Scott
Scott Shama is offline   Reply With Quote
Old May 29th, 2009, 03:05 AM   #2
I use a Manfrotto 503 head on the track, with the Manfrotto 525 legs.
The 75mm ball makes it so easy to level.
Old June 1st, 2009, 02:44 PM   #3
It doesn't matter, as long as the head have no side to side play.
I've used the glidetrack on top of a 503 head and now i use it on top of a vision 3.
Hubert Duijzer is offline   Reply With Quote
Old June 7th, 2009, 03:18 PM   #4
It does matter, I'm looking for suggestions...
Old June 8th, 2009, 02:00 PM   #5
You forgot to quote my suggestions...
May i suggest an alternative for the 503? Libec LS-38!
Old June 10th, 2009, 08:51 PM   #6
I'm currently using it on some small Manfrotto 190XDB sticks. I have the tripod directly attached to the Glidetrack and a Manfrotto 701HDV head on top. This seems to work better than my old method which was to have the Glidetrack on top a tripod/head, with another head on it. Now I'm looking for a way to put something on either side of the Glidetrack so that it doesn't tilt when I get the camera all the way to one end. The camera weighs a little under 5 lbs.
Chad Dyle is offline   Reply With Quote
Old July 23rd, 2009, 02:55 AM   #7
I'm reviving this thread since I now have the identical question.
Scott -- did you ultimately decide on a setup? How are you liking it?
Anyone else want to weigh in on this setup recommendation thread?
~ Charles
charles baisden | paper pusher & owner
http://www.fusionphotovideo.com
Charles Baisden is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Dolly / Track / Cable
