DVD recorder that does simple cut edits at DVinfo.net
Old February 7th, 2008, 10:16 PM   #1
Is there a good set top DVD recorder that allows cutting out sections after capture? A good example would be capturing a 2 hour VHS tape of a broadcast and clipping out the commercials. I think some recorders have Hard drives that you record to and allow simple edits before you burn to DVD.
Any suggustions? Do they have a simple interface for a menu?
Brian Jansen is offline   Reply With Quote
Old February 7th, 2008, 10:57 PM   #2
Hi Brian,
I have two Panasonic and two Phillips HHD DVD burner units. Each of them do what you want. The Phillips units are newest and can be found at WalMarts for about $300.
There are also units that combine a VHS Recorder and a DVD Burner in one unit.
Harold
Harold Schreiber is offline   Reply With Quote
Old February 7th, 2008, 11:16 PM   #3
thanks Harold for the quick reply! Can you recomend the better choice or maybe a model number? Thanks
Old February 8th, 2008, 01:44 PM   #4
I have a Panasonic with an 80GB HD and I was really impressed of its encoding capabilities. It can fit 2 hours on a DVD with quality very similar to the best software encoders (of course it can fit up to 8 hours on a DVD with the recorder, but that's just out of the question quality-wise)
Heiko Saele is offline   Reply With Quote
Old February 8th, 2008, 02:42 PM   #5
HI Brian,
Not sure what Pana has out curently, but they are good.
The Phillips seems to do as well as my Pana's, and cheaper with a 160 gig HHD. All new units have the Digital /analog tuner.
Harold
Old February 8th, 2008, 04:03 PM   #6
Thanks.... I'll do some checking on current models.
