ULead DVD Workshop Question at DVinfo.net
Old May 11th, 2004, 11:34 AM   #1
So I'm working on a wedding video. I finished editing with Premiere Pro, ecoded it to mpeg 2 with my Matrox card. Everything fine so far.
I come to the conclusion that it will not fit on one disc. I put the first 1:48 on the first and it went fine. Everything looks and sounds decent.
After finishing that step, I went back to the edit section and tried to set a new IN point, right where I left off. I only want to burn what didn't fit on the first disc.
My problem is that the sound now is not synced. If I return the IN point to the beginning, it's fine, but when I move it, the pictures are start where I move the IN point, but the sound begins at the start of the video.
Anyone know what I'm doing wrong?
Or am I going to have to go back into Premeire and encode a separate section. I know I could do this, but it seems much easier to address the ULead Problem.
Chris Frame is offline   Reply With Quote
Old May 11th, 2004, 03:07 PM   #2
Which version of DVD Workshop are you using?
Have you applied the latest patches?
Nick Jushchyshyn is offline   Reply With Quote
Old May 11th, 2004, 08:43 PM   #3
Thanks for the link to the patches. I should have looked there first.
The problem is, even after downloading, installing, rebooting, it had no effect at all.
I move the set it mark and the audio always starts at the beginning instead of where it should. It's very maddening.
