Workaround - connecting audio clips to gap clips? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old December 15th, 2011, 12:32 AM   #1
Images: 32
I'm trying to lay down an audio bed by connecting an audio clip to a gap clip. But for some reason the snapping feature doesn't work with gap clips. So when I try to connect the audio clip to the start of the gap clip it just slips and slides around, occasionally trying to insert itself onto the storyline. Urrrrrgh .... I just hate it when my timeline actions aren't accurate.
Is there an elegant and proper way to do this? Like a way to specify exactly where a clip is connected to another clip?
My current workaround is to position the playhead at the beginning of the gap clip by using up/down arrow key then snapping the audio clip into place with the playhead.
Thanks in advance for any advice.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
