Import FC Express file into FCP X at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old May 7th, 2012, 08:23 PM   #1
Hi All
I've just upgraded my Mac and am trying to get a current project from my old Mac in FC express into the new set up but am struggling.
Its probably easy but I have exported it as a .mov file and as a FCE file but FCP will not import it.
Am I faced with having to start again or is there something I am missing?
Thanks for any help.
Cheers
Ryan Wallis is offline   Reply With Quote
Old May 9th, 2012, 12:16 AM   #2
Re: Import FC Express file into FCP X
Import into FCP 7, export to XML and then import into Premiere?
Chris Hsiung is offline   Reply With Quote
Old May 9th, 2012, 09:51 AM   #3
Import into FCP7, export XML and then convert using 7toX which is available on the App Store. Unfortunately the drawback of FCE is the lack of pro export options such as XML. Otherwise, exporting a self-contained mov file should work just to get a finished project into FCPX.
Old May 14th, 2012, 12:57 AM   #4
Thanks guys
I exported the FCE project as a mov file but FCPX will not import that? Am I exporting it incorrectly some how?
I don't have FCP 7
Old May 14th, 2012, 06:26 AM   #5
Does that movie open in QuickTime? And how big is it? An SD file should be at least 1gb per five minutes.
Old May 15th, 2012, 07:29 PM   #6
No, the .mov file doesn't seem to open in Quicktime...its about 15 GB in size
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
