Synced clips: adjust audio channels separately? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old July 5th, 2015, 04:48 AM   #1
I shot an interview with a GH4 using a wireless mic and recorded my own voice on a Zoom H1. I've synced the clips and now I want to make a mix of the two audio channels. Is that possible with this workflow?
I can't figure it out. I can turn off one channel but I don't want that. And when I lower the volume -even with one channel disabled- it affects both.
All I want is to be able to lower the volume on one channel. Should be simple...
www.imaginevideo.nl Just published the second of my viral mini-doc series '100'
https://youtu.be/ZqHFBrV-oOc
Jeroen Wolf is offline   Reply With Quote
Old July 5th, 2015, 07:13 AM   #2
Re: Synced clips: adjust audio channels separately?
Try this: right click the clip and select expand audio components.
Synced clips: adjust audio channels separately?-image.jpg
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old July 5th, 2015, 07:23 AM   #3
Nate: that's so simple even I can do it ;-) !
Great help, thanks.
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
