PXW-FS5 and FCP X at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old November 21st, 2015, 10:08 AM   #1
PXW-FS5 and FCP X
Hi folks,
I am back with a question to that I can't find an answer:
Anyone knows how to import files from the new FS5 to FCP X without Catalyst?
Markus
Freelance full service reporter
www.boehnisch.de
Markus Bo is offline   Reply With Quote
Old November 21st, 2015, 06:04 PM   #2
Re: PXW-FS5 and FCP X
Import from an SD card readers. I have the lowly x70 but it's basically the same codec and card structure. That works for me. FCPX 10.2.2.
Old November 21st, 2015, 10:58 PM   #3
Craig-
What is xvac-L like in your edit system?
Thanks in advance for any insights you care to share.
Be well.
Rob
Smalltalk.Media/NYC
Rob Katz is offline   Reply With Quote
Old November 22nd, 2015, 04:12 AM   #4
That's interesting to read. Yesterday I got a copy of a card structure form that camera, copied on an SD and FCP X crashed....it seems to be a problem of my system.
www.boehnisch.de
Old November 22nd, 2015, 02:12 PM   #5
Not an FS5, but for what it's worth, native use of the XAVC-L from a Sony X70 in FCPX requires:
-footage shot on a camera that's had the latest firmware update (not the same as the 4K update)
-latest version of FCPX
-latest update of Yosemite (or El Capitan)
...and of course the card structure - the entire Private folder and below from the memory card.
David Dixon is offline   Reply With Quote
Old December 1st, 2015, 09:35 AM   #6
My workflow is SD card in FCPX, Create Camera Archive, Import from Camera Archive.
Sometimes it looks like it takes a minute or so for FCPX to see the card structure, properly joining clips. Import from Camera Archive is always spot on with immediate recognition of the structure.
I don't need to go inside any folders. I simply Camera Archive the entire card as is.
I'm only recording one format (frame rate/codec) per card.
Using a late 2013 6 Core MacPro. Handles the native XAVC-L without any issues.
Craig Seeman is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
