how to use compressor at DVinfo.net
Final Cut Suite
Old August 9th, 2007, 04:19 PM   #1
Hi Guys
Can someone give me a detailed description on how to use compressor. I have three items that need to be put on a dvd- full version - highlight - love story. How does this thing work?
thanks
Jason Bowers is offline   Reply With Quote
Old August 9th, 2007, 04:21 PM   #2
Also can I just export to quicktime movie or will this not work? I am switching from ppro2 and need help with the finer details.
Old August 9th, 2007, 06:42 PM   #3
in FCP with your sequence open select export>using compressor
In compressor pick your settings from the setting palette and drag it into the window that say "drag settings and destinations here". Then pick your destination and drag it on top of each of your settings. Hit submit and you're all set.
Josh Laronge is offline   Reply
