JES Deinterlacer problem: HELP! at DVinfo.net
Final Cut Suite
Old October 30th, 2007, 10:44 AM   #1
I don't know what to do - I set some batch files to inverse telecine, but JES DeInterlacer choked and crashed on them. Now every time JES Deinterlacer is started up, it automatically tries to convert the same files and crashes.
Advice?
Brian Boyko is offline   Reply With Quote
Old October 30th, 2007, 02:25 PM   #2
You might have to go into your ~/Library/Preferences folder and delete your nl.jes.deinterlacer.plist file... it's been a while since I had that problem, but I think it keeps the batch export list in the preferences file...
you will lose any settings you've configured so far so you may want to try renaming the file or dragging it out to your desktop first.
Also check with the Activity Monitor to see if there's any more JES applications running after you've quit JES DeInterlacer, there might be a runaway process still going.
Kelly OHara is offline   Reply
