Anamorphic blunder at DVinfo.net
Final Cut Suite
Old November 3rd, 2007, 08:02 PM   #1
Anamorphic blunder
Well, I shot an event in 16.9 ratio and have captured the first tape non anamorphic. I was wondering if I'll need to recapture or can is there a way to get around this? Thanks. I'm editing in FCP 5
Jim Benton is offline   Reply With Quote
Old November 3rd, 2007, 09:29 PM   #2
In the browser window in FCP scroll until you see the "anamorphic" column and add a check mark to each clip that was shot in 16x9.
-A
Andrew Kimery is offline   Reply With Quote
Old November 3rd, 2007, 10:52 PM   #3
Anamorphic
Another way is to click on the motion tab, then click on distort then type in -33.33 under aspect ratio.
Jon Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old November 3rd, 2007, 11:35 PM   #4
Jonathan's advice is correct, but that may not be the right number. As you are using a 16:9 timeline, I assume, you'll probably want to use an aspect ratio of 0, meaning that it matches the timeline (it will be 33.33 to start; if it was a 4:3 timeline, the -33.33 value would be correct).
Daniel Ross is offline   Reply
