Full Screen Mode Freeze at DVinfo.net
Final Cut Suite
Old November 19th, 2007, 10:30 PM   #1
For the last week I get a frozen frame when I look at a sequence in Full Screen Mode in Final Cut Pro. When I hit play, it just stays at whatever frame it was I switched to full screen. The only exception is when (if the sequence is paused) I advance one frame at a time using the right arrow, it will advance that way. Any thoughts about what might have gone wrong?
My "main screen" is a tiny 15 inch I only use to look at the bin and my secondary screen is a 24 inch dell. Never had any problems for two years until last week. The only thing that's changed is I've been spinning my wheels a lot trying (unsuccessfully) to transfer a multi layered pal 1080i originated 50fps sequence to a decent looking ntsc 480 dvd for 4x3 tvs and God knows what wrong button I might have pushed in the process.
Thanks so much if ya'll know what it might be:)
Betsy Moore is offline   Reply With Quote
Old November 19th, 2007, 11:16 PM   #2
Go to the View Menu, and check to make sure your video playback is set to "All Frames" and not "Current Frame"
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old January 21st, 2008, 09:19 PM   #3
I did... unfortunately that wasn't the problem, thanks though. Any of you guys have any other ideas?
