Problem with compressor? at DVinfo.net
Final Cut Suite
Old November 27th, 2007, 12:36 PM   #1
I am trying to make a hdv project smaller but I am having problems when I import my quick time mov ref file into compressor it dose not give me the option to record to a dvd-5 it comes up as H.264 for dvd studio pro why is this should I not have more options.
Gary Williams is offline   Reply With Quote
Old November 27th, 2007, 04:30 PM   #2
Gary,
which version of Compressor? In the latest (Compressor 3), there's a window called "Settings" from which you drag a preset to the imported file entry in the main window, thereby adding the selected output/encoding type to the job in your batch window.
http://manuals.info.apple.com/en/Com...ser_Manual.pdf
Compressor 2 worked a little differently, but basically the same decisions/inputs need to be made: add an input file to a batch, then for each input file add all desired kinds of output to the batch. Finally, start the batch.
Oh, and you may need to add a destination for each produced file, too.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old November 27th, 2007, 09:28 PM   #3
Your right I have compressor 3 and the interfase is different thanks for the manual I will go through it and see if I can figure this out. Gary
