HD clip export problems at DVinfo.net
Final Cut Suite
Old November 9th, 2008, 10:22 AM   #1
What compression format is recommended for export of a 30-sec. HD clip that is to be uploaded to the Web? I've tried several (resulting in file sizes ranging from 311-480 mb) and all have yielded poor playback quality. Also, I can't get any of the clips, which I've saved to a desktop folder, to appear in the correct 16x9 aspect ratio, even when I play them it back through my Quicktime Player.
David Koeppel is offline   Reply With Quote
Old November 10th, 2008, 12:52 AM   #2
is it for you tube?
http://www.dvinfo.net/conf/dvd-web-v...sion-tips.html
http://www.dvinfo.net/conf/dvd-web-v...-terrible.html
Encoding for YouTube Using Compressor
YouTube Encoding: Locked & Reloaded
Brian David Melnyk is offline   Reply With Quote
Old November 10th, 2008, 09:06 AM   #3
Export using QT Compression, select Broadband High (or Medium), go to options and select H.264, and Custom size, and enter 480x270. This should give you a small file size of good quality.
Dick Campbell is offline   Reply
