Convert from powerpoint to quicktime at DVinfo.net
Final Cut Suite
Old February 11th, 2009, 08:50 PM   #1
Hi Guys
How would i convert from powerpoint to quicktime
Rob
Robert Bec is offline   Reply With Quote
Old February 11th, 2009, 09:25 PM   #2
Not sure exactly what you mean.
If you're trying to get a traditional powerpoint sequence of still images to video, there are LOTS of ways, including exporting the slides to JPEG or Tiff stills, then you can import them onto any typical video timeline for further editing.
If you want to capture powerpoint annimations, you can export as a stills sequence - or you can play them in real time and use a video capture program on a laptop - or even just point a camcorder at the laptop screen and record the results.
It all depends on the quality and accuracy of the results you're seeking.
If you're talking about exporting a video embedded in a powerpoint presentation and transcoding it to Quicktime - again, there are a whole bunch of ways.
You just need a software tool to rip the video stream out of the powerpoint file, then a WMV or AVI to Quicktime converter.
If you could be a bit more specific, perhaps we could help you more?
Old February 11th, 2009, 10:51 PM   #3
A client has given me a powerpoint file she would like it included on the DVD with the rest of her video.
I would like to take the powerpoint file and turn it into a quicktime movie so all i have to do is drop it on the timeline of FCP
I hope that made sense
Rob
Old February 12th, 2009, 01:21 AM   #4
Beware of this part of the job. You're going to DVD, so make sure you keep all the contents of the slides within the safe zone of an SD 4:3 screen. Also, certain slides will just plain look bad on an interlaced display. Best case scenario is you take the slides into Photoshop and treat them accordingly before going into FCP.
Eric Darling is offline   Reply With Quote
Old February 12th, 2009, 05:12 AM   #5
If you have iWork, you should be able to open the Powerpoint in Keynote. Keynote has the ability to export as a QuickTime movie (if I recall correctly).
David Knaggs is offline   Reply With Quote
Old February 12th, 2009, 08:21 AM   #6
Yes, this works but not always cleanly so double check it. You can also use the new Mac version of PP which has a Quicktime export feature. I haven't used it but I hear it works.
Jon Bufkin
focalpointcinematic.com
Jonathan Bufkin is offline   Reply With Quote
Old February 12th, 2009, 09:29 AM   #7
Better than Halle Berry
There's a funny phrase I've heard used in many businesses- beware of death by Powerpoint...
Noah
Noah Kadner is offline   Reply With Quote
Old February 12th, 2009, 09:34 AM   #8
Go Go Godzilla
Images: 15
It might make more sense to take screen-grabs of certain sections of the PPT and refer to them in the clip rather than export the presentation itself as a movie. This is because you can't control how fast each slide is presented when it's transformed into a movie, the user is stuck with whatever cadence is created. And since many PPT's dont' even advance until the user commands it you might have to restructure the entire presentation to have a natural cadence.
Keynote is very capable of exporting presentations in any codec and quality setting that you can imagine; when you select a "custom" QT output you have the full range of options that you would using Quicktime Conversion from FCP including data size, frame rate, codec, sound options etc. This is far away more than PPT could ever accomplish. (see screen-grab)
There is another option: you can add the PPT presentation as ROM content on the disk thereby allowing the user to actually put the DVD into any computer (Mac or PC) and copy off the presentation in it's original format and then play it in PPT or Keynote directly. DVDSP has this option - see image.
So you have a lot of options actually, you just need to choose which one fits your production best.
Convert from powerpoint to quicktime-dvdromadd.001.jpg   Convert from powerpoint to quicktime-keyexportopts.jpg
Old February 12th, 2009, 10:03 AM   #9
Having endured this request as well I ended up redoing the presentation in photoshop so the slides are in safe zones and are a better resolution and also tweaked the fonts and drop shadows to help make the slides more legible on a TV. I then used Encore and imported each slide as a menu so that it stays up on screen as long as the presenter wanted and would be able to advance to the next slide with the remote. Not easy or fun but it worked.
Edward Phillips is offline   Reply
