Capturing GL2 'frame mode' footage in Final Cut Pro at DVinfo.net
Final Cut Suite
Old April 1st, 2009, 01:54 AM   #1
So I just spent an 2 hours logging clips from some documentary footage and now when I go to batch capture I get an error telling me that "You are about to capture drop-frame media to a non drop-frame clip." Is the fact that I recorded my footage using the "frame mode" on the GL2 causing this error? Are there any special Final cut system or capture settings I should change in order to capture frame mode footage?
Brian Van Peski is offline   Reply With Quote
Old April 1st, 2009, 12:48 PM   #2
No, this is a timecode issue. You should be able to change the offline clips' settings to use drop-frame timecode from the browser and then batch capture.
IIRC, the way to do this (I'm not at my FCP machine, otherwise I would try this myself first) is in the FCP browser, select all the offline clips and then right-click over one of the fields displaying timecode (for example, in the length column... not on the column header, but inside the actual column over one of the entered values). A contextual menu will appear giving you the option to change the type of timecode. This change should, again IIRC, apply to all selected offline clips.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old April 1st, 2009, 08:57 PM   #3
Awesome! Thanks Mike! I knew it had to be some sort of contextual menu somewhere but google searches came up with nothing and aimlessly clicking through all the menus I could think of in Final Cut left me without a solution. Of course it turns out I was just right-clicking in the wrong spot! :)
Thanks for your help!
