Did I capture wrong? at DVinfo.net
Final Cut Suite
Old April 14th, 2009, 09:18 PM   #1
I'm just noticed that some of the progressive footage I captured (from an XL2) has some interlaced frames. It was shot 24p. I can't remember if it was regular or advanced, but I seem to have three frames of progressive footage followed by two frames of interlaced footage. Do I have to recapture? What should my setting be in Finalcut? I was under the impression that you just captured normally with progressive footage.
Marco Leavitt is offline   Reply With Quote
Old April 14th, 2009, 10:17 PM   #2
I may be wrong since I haven't really worked with progressive, but I thought you need to set your captures settings to the Advanced 2:3:3:2 Removal.
-Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?"
- Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974
Jonathan Jones is offline   Reply With Quote
Old April 14th, 2009, 10:22 PM   #3
-Jon
And I guess you also need to double check that you sequence settings match your capture settings.
-Jon
