Data Rates... at DVinfo.net
Final Cut Suite
Old April 18th, 2009, 12:14 PM   #1
Data Rates...
I posted this in the Panasonic AVCHD area but wasn't getting anywhere... probably because I should have posted it here first!
On capture, I use 'log and transfer' and encode to ProRes422. I'm shooting in 24p. My data rates for my clips vary anywhere from 13.7 to 17.
Is this normal or anything I should be concerned about?
I like my oatmeal lumpy.
Blake Cavett is offline   Reply With Quote
Old April 20th, 2009, 01:07 PM   #2
Perfectly normal. Those data rates are inline for ProRes422 145 Mbps rate. If you do the conversion 145 Mbps is 18MBps for 30fps video (less for 24fps video).
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old April 22nd, 2009, 01:30 PM   #3
Thank you so much Rick! I've been trying to get an answer to this for a few weeks.
Thanks again!
