Lumiere HD workflow - Page 11 at DVinfo.net
Final Cut Suite
Old July 12th, 2006, 12:37 PM   #151
Doesn't anyone know?
Didn't anyone have similar experience? Please help
Rati Oneli is offline   Reply With Quote
Old July 12th, 2006, 03:14 PM   #152
Two questions:
1.) Are your m2t files sequentially numbered, as in you used Lumiere's Autoincrement function when you captured your files?
If so, then go back to step #9 of the procedure and carefully read the note about using Autoincrement.
2.) Have you posted your issue on the Lumiere HD forum?
That fact that it worked once but not this time must mean that your procedure has changed slightly.
www.SayreMedia.com
Jeff Sayre is offline   Reply With Quote
Old July 12th, 2006, 03:23 PM   #153
Hi Jeff, thank you again. :) I did post this on Lumiee forum, but no answer yet.
I did the autoincrement option, but I don't completely understand the requirment for selecting the files. In my first try I think I just selected the whole folder and it did everything correctly. Now, for the second try, I selected the files manually, but how does it makes sense since to select those files I have to access the folder anyway? Which means I have to click on the folder and open it, so the fact of opening the folder already registers with Lumiere. I have many files in there and I only want to use few, so what I did is I pointed the arrow and selected the files I wanted from bottom to top. This didn't work. So the next time I just went into the folder and selected one file only. This didn't work either...
Maybe I should just reinstall the Lumiere from the scratch? Hopefully, I won't loose the license.
This whole thing is quite uncomfortable, especially after paying $200 for it - it feels like they (Lumiere) just glued together some kind of interface together and threw it out in the street for people to have problems with it.
Old July 14th, 2006, 07:39 PM   #154
Use MPEG Streamclip
Hi Rati,
We are using Lumiere to capture only, use MPEG Streamclip to transfer to AIC files for editing in final cut pro.
Do a search for Tim Dashwood on this or the JVC thread, he's got all this stuff figured out and happily has shared his info.
Good luck,
Tom Chaney
www.tomchaney.com
Tom Chaney is offline   Reply With Quote
Old July 31st, 2006, 02:05 PM   #155
Data Dropout
When I'm in capture mode, sometimes Lumiere 1.7 will make make data from the camera dropout. I get a black screen for a split second then blue then a pop. I look back at Lumiere and it has stopped capturing. I was having this problem yesterday when I first tried to capture, so I quit Lumiere to make sure it wasn't the tape. No problems with the tape. It plays fine when Lumiere isn't running. I'm not running any other programs at the same time. It seems like Lumiere is trying to gain control of the camera, because the capture works best when the VTR controls on Lumiere aren't working and I have to control the camera manually. Any thoughts?
Steve
Cal Thorpe is offline   Reply With Quote
Old August 2nd, 2006, 03:07 PM   #156
XML does its own resizing
If I import my AIC 1280x720 MOV file straight into FCP it keeps its size. If I import the XML that Lumiere made it comes in wanky even though when I look at the movie's properties in FCP browser it still says 1280x720. Any ideas?
Steve
Old August 3rd, 2006, 02:39 PM   #157
If anyone else has had this problem, I found a fix. Wait to create your project file. Open FCP and then immediately import an XML file, instead of importing it into the already open project have it create a new project. After that, double check all your sequence settings and make sure they are what you want. Every XML file after that should work.
Old August 4th, 2006, 09:37 AM   #158
Scale Option Removed in v1.7 (don't delete your v1.6b6!)
I have just finished my first workflow test with version 1.7 and it looks like they have removed the ability to maintain the frame dimensions in the timeline tab.
v1.6b6 used to have a section underneath the codec selection that allowed you to maintain source dimensions or scale to the dimensions of your liking.
This is bad news for those of us who prefer to maintain 1280x720 in AIC and never go back to the m2v source.
It looks like they have removed this option in v1.7 and now the files always downscale to 720x480.
There also used to be an additional Quicktime dialog that appeared when you hit the GO button that allowed you to select 48KHZ AIFF and confirm your codec selection and frame rate. THis is also gone.
Tim Dashwood
Old August 4th, 2006, 09:43 AM   #159
Rati,
Sorry for the delay in response. I don't visit this sub-forum very often.
This might sound like a silly question, but did you use any "spaces" in your filenames? It is a ridiculous thing that on a mac you would be forced to used an underscore "_" but it seems LumiereHD does not like spaces.
I've also noticed it will hang if the file name you originally entered is too long. Keep it under 25 characters.
Otherwise, I'm not sure what your issue could be stemming from. I have found v1.6b6 and v1.7 to be fairly solid (even though I'm pissed that they removed scale control in v1.7 - see my other post)
Tim Dashwood
Old August 4th, 2006, 12:50 PM   #160
Hi Tim, thank you for your post. I didn't use spaces actually and I couldn't figure out what was wrong until I downloaded the latest version of the Lumiere HD. It seemed to have fixed the problem, although there is another issue now.
I selected four files to be transcoded into M2V files. It did transcode all four of them, but when it created quicktime MOV files there were only three instead of four. This was a bit misterious to me. I didn't really follow up on this and didn't do another conversion because I was busy with shoots, but I hope it won't be an issue when I begin to transcode dozens of files.
Also, I played some of the raw files M2T through VLC player and it did play most of the fine, but it didn't play some of them and for couple it gave me an error. Is it possible that I ruined the raw files by prematurely playing them through VLC player? Does it mean that I can't properly transcode those files anymore and I shouldn't trust the quality?
Rati
Old August 13th, 2006, 12:19 AM   #161
Lumiere HD cuts off my Video half way through import, audio is still good. Help!
Everytime I import a whole 63 minute tape of footage into Lumiere HD, it seems to import it all fine. But after I"m done demultiplexing it and finally getting into an FCP XML file. It cuts the vidoe only off on every tape at exactly 31 minutes 15 seconds into the tape. The whole 63 minutes of audio is still there, and I hvae to end up going back and re-importing the last half of the tape... can anybody help me?
kevin
Kevin Sabourin is offline   Reply With Quote
Old August 14th, 2006, 02:28 AM   #162
Can't you just select Custom and enter W 1280 and H 720?
James Tauber is offline   Reply With Quote
Old August 14th, 2006, 06:29 AM   #163
I was having a problem with Timeline Codec not doing anything until I noticed some of my files were only 4k (the .m2t, .m2v and .aiff). When I deleted those, Timeline Codec worked.
Old August 14th, 2006, 10:05 AM   #164
lumiere onl for capture
You can use lumiere for capture. To encode it for use in FCP you better use Mpeg Streamclip (freeware)
Han Savelkoel is offline   Reply With Quote
Old August 29th, 2006, 02:34 PM   #165
Realtime Timeline Codec File Size
I'm capturing 720p/24p footage. Can someone please clarify the FCP proxie files created in the Realtime Timelince Codec in Lumiere HD 1.7? Here are the steps I have taken so far.
1. Choose the PRESETS pull-down menu In the REALTIME TIMELINE CODEC window. Select OTHER.
2. In the COMPRESSION TYPE Pulldown menu, select APPLE INTERMEDIATE CODEC.
3. Select the FRAMES PER SECOND pull-down menu and select 23.98.
4. Select the OTHER button in the COMPRESSOR > PRESET.
5. <b>In the SIZE section, choose the SOURCE button. Note that you can also create a smaller dimension such as 720 x 406 (16:9 aspect ratio) since this is only used as a proxy in FCP to edit with. But if you have the memory and speed, working in the full 1280 x 720 is preferable. These files will not be rendered into your final master. After you edit with this proxy codec, you will use Media Manager to build a new timeline from the full size raw capture images.</b>
Disk Space is the main issue I am dealing with. Because of the additional steps necessary with the HDV 24p footage, I'm taking up tons of disk drive space already. Every GB in the m2t files folder is doubled in the Video files folder after "demuxing" plus the additional space in the Audio files folder. On top of that, the "Realtime" .mov files created after step Three in the Lumiere process (Timeline Codec Apple Intermediate Codec at 1280x720) more than doubles the original video files in file size yet again.
My undersanding in regards to step 5 above was that keeping the 1280x720 pixel size the same would not effect filesize becasue these are proxie files used during the offline. I must have misunderstood this because the .mov video files are bigger than the originals. Can I save disk size by reducing the pixel size of the FCP proxis files during the offline. I have 60 hours of footage to go through still, and I do not need high resolution during the off-line process. My undersanding is that when I create the final on-line sequence with Media Manager I would then up the resolution to Best Quality at 1280x720.
Any suggestions?
James Fortier is offline   Reply
