dv start/stop detection at DVinfo.net
Final Cut Suite
Old February 23rd, 2005, 03:09 PM   #1
When using the dv start/stop detection command in FCP it places markers on the clip everywhere the camera started and stopped recording. My question is, can FCP name the markers the same name of the actual clip it's analyizing ie:clip1,clip2 etc: instead of the default "SEGMENT 1,SEGMENT 2 ? I would not want to rename all of them individually especially if there were alot of clips.
I've tried adding comments etc: to the logging field but to no avail. Anybody else using this feature ??
If so is there a workaround ??
Thanks.
Mike DelliSanti is offline   Reply With Quote
Old February 24th, 2005, 06:18 AM   #2
I use the feature but am unaware of a workaround for what you describe. You may try the LA FCP User Group website as alot of highly skilled FCP folks hang out there.
Old February 24th, 2005, 12:13 PM   #3
Thanks Ernest. I'll try all the FCP user groups, since I'm not getting any answers other than yours that I posted on other FCP forums.
Old February 24th, 2005, 12:42 PM   #4
Have you tried to set the first Marker (and name it) on the "logging" tab manually as well as naming the "bin"? I haven't tried it myself since I specifically try NOT to break timecode while recording. It's a good question though, let us know if you figure it out.
Rhett Allen is offline   Reply With Quote
Old February 28th, 2005, 07:57 PM   #5
Kind of but not really. I;ll try it out in more detail after I finish this current job I'm working on , must be done by Fri. I'll keep you posted.
Old March 7th, 2005, 09:23 AM   #6
I tried setting the first marker but that doesn't work either.It uses the name you give it but the dv/start stop command doesn't work on markers only on clips.
