something like iDive but for windows at DVinfo.net
Final Cut Suite
Old May 2nd, 2005, 09:03 AM   #1
hy there...
Sorry if there is a problem becouse I was post the same topic on "non linear editing on windows"..but...there no one know answer...looking for program similar to iDive but for Windows...Any suggestion?
(iDive is a digital Video Catalog and Exploration tool to be used whenever you want to Find quickly and efficiently Clips or photos inside your DV Footage.
iDive will transform the growing amount of data on your physical tapes into a well Organised, easy to navigate Visual Catalog.
Capturing and Compressing your data will be as Easy as connecting your camera and hitting the record button.
Clip Annotation of the clips is guided by a User-friendly interface and built in concepts such as People, places and Events)
Cesar Perez is offline   Reply With Quote
Old November 1st, 2005, 03:02 PM   #2
I am looking for the same but with no luck, the dv tapes are ruining my life and my memory...
Agus35 - the ultimate tool for indie DV filmakers -
Agus Casse is offline   Reply With Quote
Old November 1st, 2005, 03:06 PM   #3
Images: 1
I believe the latest release of Scenalyzer has a function such as this. Might want to check it out.
-gb-
Old November 1st, 2005, 07:13 PM   #4
not really, cause it only works for capture, not to catalog and search a specific content of your tapes.. i have tried and tried catdv with no reaults cause it is way to complicated to use and you need a winVDIG driver that i cant found anywhere or i could buy ... (which i dont want cause i dont even know if it will work)
I amazed how is that dv catalog software is not important for software companies with a such large market.
