MicroDolly Hollywood
Pixelation/Compression Problem
I'm having a little trouble with some of the images I'm capturing and wondering if anyone can help.
I've got FCP4 and I'm downloading footage into my External Hard drive from my DVX100. I'm not shooting in the progressive 24p mode and all my settings are correct for DV in Final Cut. I have added some filters, including widescreen and color correction, but when I view my footage in the timeline I can see pixelation in the background colors. The background walls will have pixelated boxes with lighter and darker boxes that will move and swirl about behind the talent in the shot. I will see this pixelation in the canvas, but I will also see it in the DVD that I burn from DVD Studio Pro. So, I'm sure it's not just "playback" quality. A computer-geek friend of mine says it's a problem of compression, but I'm not sure where the problem is. I've got all the capture and render folders in the same external drive, all going through FireWire. And all the footage has been properly rendered. I've even tried to desaturate the color so the computer won't try so hard to find the "correct" color on that background. He suggested that I re-capture the footage and try again, but it's happening in nearly every project I start. Anyone dealt with this?
www.microdolly.com Jibs, Dollies, Camera Mounts |
Are you using secondary color correction in the 3way CC filter? If so, hit the show mask button and see if you see the pixelation/blockiness there.
The 4:1:1 color smoothing filter may help a little, along with the softness settings in the 3way CC (drag the bottom sliders out so it the limit effect settings look like chopped off pyramids). 2- With no effects, do you see your problem? |
I did not use the 3-way corrector, only the basic corrector.
I'll give that a try. Will the color smoothing make the picture any less sharp or more out of focus? When I turn off the effects, the problem is still there. However, when I look at the original footage in the bin, it is not there. Which is why I was concerned about some sort of compression problems. I should be able to add any effect without causing problems with the picture. And it's not on every shot, only a few select scenes. It's not a specific color (like Reds) either. I'll try the 3-way filter today.
That's odd. Try this experiment: create a new empty sequence and drop a clip into it. Does the bar above the track turn green or is it light blue? If it's green then that indicates FCP wants to render the sequence. That would mean something is mis-matched between the clip and sequence settings, and that might be the culprit. Carefully look at the properties of each.
If the bar is blue, then do you see the blockiness in this new sequence? Does it look different than opening the clip itself in the viewer? You said the original clips look clean, so this probably isn't the problem, but there has been a lot of discussion about noise in DVX-100a footage under certain conditions. I'm not personally familiar with that camera, but it might be worth digging through our DVX forum to read up on this issue. |
#5 |
Hi Tim,
I don't think the 3-way Color corrector filter would help. My advice would only apply to the 3-way CC filter bringing out artifacts in DV-compression video. I would look into what Boyd is saying (your problem may be a settings mismatch). Something else that may help is to get properties on your footage. Check that they are DV... and not PhotoJPEG or something like that. |
#6 |
Well, the 3-Way CC didn't work. I fooled around with most of the options, one at a time, and it didn't make it better.
I copied one of the bad scenes and pasted it into a new sequence, and the system wasn't looking to render it at all. It stayed gray. I have a feeling it might be a problem with the DV footage coming directly from the camera. If anyone has any other suggestions, I'd appreciate it. Thanks for the input so far.
#7 | |
#8 |
I opened up the original images in the bin. They are okay, but not perfect. I found that by making even slight adjustments in the contrast, or tweaking the color just a little bit, that the problem surfaces.
The image is "fine" before I touch it, but the image does need to be tweaked with some color correction so I can't leave it as-is. But whenever I do just about anything to it, it starts causing the image problems. That's what leads me to believe that it's in the original images. The problem is there, just waiting to jump out.
#9 |
Oh, well in that case it sounds a lot like that's just the way your footage is. Unfortunately, depending on the nature of the scene, exposure, etc, you are limited in how much manipulation can be done without having problems like these...
#10 |
I'm glad you brought up this issue Tim. I'm having the same problem only with footage I shot last week on a panasonic GS-70. Initially I thought it might be a bad vid card but I don't think so. And for the life of me I can't figure out what's causing it. I appreciate the input from everyone and will see if using these suggestions fixes the problem.
doug
Would someone turn on the lights!? |
