Remove chromatic aberrations in FCP?? at DVinfo.net
Final Cut Suite
Old June 11th, 2006, 03:10 PM   #1
I've got a couple of important shots with some chromatic aberrations around the edges of white... is there an easy way to remove these using FCP's built-in tools and filters?
Nick Weeks is offline   Reply With Quote
Old June 11th, 2006, 07:36 PM   #2
did a quick google
This one seems to be the easiest to replicate in editors such as FCP
http://www.bytephoto.com/photo-editi...berrations.php
The results of the above tutorial:
http://www.rileyharmon.com/temp/b&a.jpg
(I had to use the eye dropper to select the colors. You should be able to do the same in Final Cut)
try out some of these and see if you can play around in FCP
http://www.paintedstork.com/digiblog...errations.html
http://www.google.com/search?client=...=Google+Search
http://www.photos-of-the-year.com/articles/adobe-raw/
Riley Harmon is offline   Reply With Quote
Old June 12th, 2006, 08:58 AM   #3
Thanks for the info... I did a search and came up with all this photo related stuff, but didn't think to apply it using FCP. I'll give it a try and see what happens
Old June 12th, 2006, 02:52 PM   #4
Nick, you may want to check out the Cheap Lens FCP-filter by River Rock Studios:
http://www.riverrockstudios.com/rive...cheapLens.html
Let us know if this works for you!
Cheers,
Ron
Ronald P. Pfister
halimedia - digital solutions and services
www.halimedia.com
Ron Pfister is offline   Reply
