HDV to DV field issues at DVinfo.net
Final Cut Suite
Old July 3rd, 2006, 06:18 PM   #1
Ive been looking around and there seems to be some serious workflow issues with HDV and DV in FCP.
I am working on a project at the moment. Its a DV project, and i've imported an HDV clip into the bin - not the timeline. I'll launch the HDV clip in the Viewer and mark my ins and outs and then export to uncompressed 8 bit.
My question is which field order do i use, or more so, when do i change field order?
I have currently been exporting upper field and then once in the dv project, making the clip lower field. However, this is resulting in a a bit of flicker. Any ideas?
Cheers,
Ben Gurvich
Ben Gurvich is offline   Reply With Quote
Old July 4th, 2006, 06:53 AM   #2
Ben:
Have a look at this Apple article and see if it helps!
http://docs.info.apple.com/article.html?artnum=301753
www.SayreMedia.com
Jeff Sayre is offline   Reply With Quote
Old July 4th, 2006, 07:24 AM   #3
thanks for that Jeff, I thought going from HDV to DV would yield somewhat better results anyway.
Perhaps my footage was lax
Ben Gurvich
