Interesting question about editing HD/previewing SD - Page 2 at DVinfo.net
Final Cut Suite
Old January 31st, 2007, 01:45 AM   #16
Originally Posted by Andy Mees
. . . that means what you see on the ACD is a more accurate representation of the true video quality than you would otherwise be able to see, except by outputing to a true HD monitor. basically its a good thing, not a bad thing.
At this point in time, other than buying a true HD capable monitor and an HD I/O card, the MXO is probably your cheapest route to high quality monitoring of HD.
Thanks Andy. I'm also wondering about the effect of the slow refresh rate on the ACD and what it might do to certain moving images despite going through the MXO.
Although much more costly, would you say the Panasonic BT-LH1700W HD/SD LCD monitor is a "true HD capable" monitor? If using the dvi-out of a G5, what piece of added hardware or adapter is needed to connect via the SDI input of the Panasonic? Just trying to compare how much more it might cost to go for "true HD capable".
List My Threads
Chris Gorman is offline   Reply With Quote
Old January 31st, 2007, 07:37 AM   #17
Yep, the Panasonic is great monitor for the price.
In addition you need to add an HD capable I/O card like those provided by AJA and Blackmagic. The Kona card's from AJA are very highly regarded as is their customer support.
However if you want to use the DVI out of the G5's gfx card then you're still looking at the MXO. It's the MXO magic that routes the YUV through the DVI and thence out the HD/SD SDI on the box. Without it the signal output from the DVI is RGB.
Andy Mees is offline   Reply With Quote
Old March 26th, 2007, 02:08 PM   #18
FYI, I have a review of the Matrox MXO on my blog...finally.
www.lfhd.net
I haven't tried it with interlaced footage yet. I'll have to capture some DV footage and see what it looks like.
Shane Ross is offline   Reply With Quote
Old March 27th, 2007, 12:58 AM   #19
hd monitor accuracy
Originally Posted by Shane Ross View Post
FYI, I have a review of the Matrox MXO on my blog...finally. . . .
www.lfhd.net.
Read your blog and have a question. That calibrator is for print, isn't it? How do you calibrate for yuv? Or did you just eyeball it using the Sony monitor as a guide?
List My Threads
Old March 27th, 2007, 03:25 AM   #20
The Spyder? That calibrates the monitor for photos basically. It does this by balancing the grey scale mainly. Once that is set, then the image from the MXO was spot on. Now, the new version of the software is reputed to have controls to adjust the colors on the monitor. Which is good, because that is something that the current version lacks. It just happened to be right on. At least to my eye.
Old March 27th, 2007, 10:24 AM   #21
calibration
I guess you mean that you used the adjacent sony monitor as a guide, and adjusted it to match that, right? In other words, you can't really calibrate for video unless you have a true hd crt video calibrated monitor sitting next to the ACD or whatever lcd. If that's the case, it seems the MXO is not really going to solve the problem for anyone who doesn't also own a calibrated hrt.
List My Threads
Old March 27th, 2007, 11:58 AM   #22
No...I did NOT use the Sony monitor as a guide, but rather as a COMPARISON. I just let the Spyder do it's thing...it calibrated the monitor. Then, I launched FCP, loaded bars on both monitors...loaded the same image on both monitors...and compared. I made NO adjustments after I had the images up. I couldn't...there were none to adjust. That feature is lacking in the current version. The NEXT version, however, is touted to have these features, allowing you to adjust the colors...and even get you a BLUE ONLY option. In that case, I would then calibrate to bars....just like I do with the Sony CRT. This is all by eyeball...so it takes a trained eye.
Old March 27th, 2007, 02:04 PM   #23
calibration
The Spyder? That calibrates the monitor for photos basically. It does this by balancing the grey scale mainly. . . .
If you set the greyscale for print, you are looking at a gamma different from video gamma. So I don't get it. Seems this might be fine for photographers and those producing for print, not video.
I'm hindered by not having an ACD to play with or look at settings. So maybe you select a setting so the ACD switches between RGB and YUV preview?
List My Threads
Old March 27th, 2007, 02:54 PM   #24
First...yes, the monitor calibration sets up the monitor for COMPUTER gamma. What the Matrox MXO does is converts that gamma, rather well, INTO A VIDEO GAMMA. That is what it is designed to do. So if you have it properly calibrated, the MXO can properly convert it. That is the whole reason behind the MXO.
Second...AFAIK, you cannot switch between an RGB and YUV preview.
Old April 1st, 2007, 07:50 AM   #25
Does the KONA or BM do the same thing?
Will the Kona or BM cards give you the same capability to monitor footage RT and CC.
Michael Richard is offline   Reply With Quote
Old April 21st, 2007, 10:51 AM   #26
just curious.. but you can use any lcd that supports hd and has dvi right?? i have a HP2335
Matt Hagest is offline   Reply With Quote
Old April 21st, 2007, 11:04 AM   #27
Matt, depends if the monitor is 24" and can get 1920x1080 resolution. My Dell and the Apple monitors go to 1920x1200, so there is plenty of space. Anything less and you aren't getting a pixel-for-pixel representation.
I have no experience with that monitor, so I cannot say for sure. But I know the MXO works best with the Apple because the refresh rate is exactly 59.94. The Dell has 60Hz straight up, so there is a little wiggle at the top with a couple scan lines.
Old April 21st, 2007, 08:34 PM   #28
SD preview of HDV now in FCP 6
worth noting is that FCP6 now natively supports previewing HDV footage over firewire as a downconverted DV stream
(please don't anyone confuse this with what the MXO is doing as is being discussed here ...needless to say, the MXO is a far superior color critical solution for previewing broadcast quality in HD)
Old May 8th, 2007, 02:22 PM   #29
Huh? Where is this info? So do you mean edit hdv but feed an SD monitor and do my color correction?
Scott
Scott Shama is offline   Reply With Quote
Old May 8th, 2007, 05:51 PM   #30
"Huh? Where is this info? So do you mean edit hdv but feed an SD monitor and do my color correction?"
From the Matrox website:
http://www.matrox.com/video/products/mxo/
Also my blog:
http://lfhd.blogspot.com/2007/03/matrox-mxo-part-2.html
You can feed your SD monitor and color correct in a STANDARD DEF space, because the MXO does downconvert. Or, you can feed an Apple 23" display and color correct in an HD space.
