Faster Digitizing possible? at DVinfo.net
Final Cut Suite
Old January 17th, 2007, 12:22 PM   #1
Alright. Here's the deal. 5 cameras x 10 hours x 2 days. I have 10 hours x 2 days to digitize the tapes.
Obviously there's no way to digitize all the tapes in those 2 days. However, I'm hoping to at least get more then 20 hours done.
Question 1 - is there any way to speed up the digitizing (FCP 5.1) without losing data?
Question 2 - if i were to digitize some tapes in Premiere, could i import the files into FCP without issue?
Lisa Shofner is offline   Reply With Quote
Old January 17th, 2007, 12:29 PM   #2
On the PC platform, you can try our Enosoft DV Processor.
We have successfully connected THREE cameras at the same time and captured to separate files. i.e., 3 x 1 hours captured in 1 hour. Many capturing tools don't let you select from multiple devices that are attached.
I had 15 hours of safari footage and captured the lot in 5 hours.
Connecting three devices through a single Firewire port can be problematic - it all depends on the order the devices are connected, powered on etc.
Right now, the software is free to use (in beta).
Re converting PC-based AVI files for use in FCP, QuickTime Pro should let you do that.
John Miller is offline   Reply
