Problem opening Final Cut Pro at DVinfo.net
Final Cut Suite
Old March 12th, 2007, 11:09 AM   #1
Guest
Posts: n/a
I've had Final Cut Pro 5 installed on my G5 tower for over a year now and use it frequently. But now there's a problem. When I click on it, it looks like it's loading up, it displays the initial flash screen that tells you the license number and all that, but then after that, instead of opening up into the program, it just goes back to the desktop. There's no arrow over the Final Cut Pro icon, it's just completely unopened. You can repeat that process over and over but it won't open.
I completely uninstalled Final Cut from the computer (including the files in Receipts and Libraries) and reinstalled it, and it's still doing the same thing. I don't know what to do. If anyone can help, I would really appreciate it.
Old March 12th, 2007, 07:44 PM   #2
Have you added any new hardware to your system?
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old March 13th, 2007, 05:48 AM   #3
Zach, In case you haven't already, I'd suggest you check out the FCP forum (http://discussions.apple.com/forum.jspa?forumID=939) at the Apple website.
In the last few months there have been OS, QT and FCP updates which have caused a variety of problems, some related to hardware and some to software installed. The forum is really active, with a lot of experienced users participating daily. I haven't had the problem you describe, but I have seen similiar threads at that site. Doing a search there might get you up and going again.
Tom T
Mac Pro, Final Cut Studio 2, CS2, Merlin, DVRigPro, VX2100s, HV30
Tom Tomkowiak is offline   Reply With Quote
Old March 13th, 2007, 07:20 AM   #4
Guest
Posts: n/a
Thanks to both of you for responding. After reading through a lot of threads, I tried trashing all of the preferences from FCP using one of those little programs that do that, and now it opens up fine. I really appreciate the time you took to reply. Thanks.
