FCP Multiclips and clips from FS-4ProHD at DVinfo.net
Final Cut Suite
Old May 18th, 2007, 09:14 PM   #1
I've just finished shooting a long format program using two cameras, one of which was recording to an FS-4Pro HD. I want to bring the clips into FCP and use multiclp editing but the FS4, due to FAT32 limitations, breaks the video into >2gb clips resulting in numerous clips on the FS4. I've imported them and placed them on a timeline and they play seamlessly (no dropped frames or audio). My question is: How can I turn these clips into one clip and then use it in multiclip mode. I've used a flash to establish a sync point but can these multiple clips be turned into one clip for the edit?
Does this make sense??!?
Reed
Reed Gidez is offline   Reply With Quote
Old May 19th, 2007, 03:02 AM   #2
As you have brought the clips into a sequence, highlight the sequence in the browser and click File/Export/Quicktime movie. Save the sequence as just a reference movie (uncheck 'make movie self contained'). Then import this small quicktime file back into FCP, it is then treated as a normal movie file where you can select with others to start a multi clip sequence.
James Miller is offline   Reply With Quote
Old May 19th, 2007, 06:20 AM   #3
James
Thanks. I'm running through that now but the QT write is going to take about 22 minutes on a 25 minute clip. This totally defeats the purpose of 'tapeless' acquisition as I am not saving any time by not having to digitize the files.
I shot a ballet with two cameras and wanted to edit each act in a multiclip sequence. The acts are only about 24-25 minutes each but now it seems that tape would have been just as good in this sense.
Old May 19th, 2007, 06:31 AM   #4
Are you trying to save as a reference quicktime file? The end file size should be tiny as no re-encoding takes place.
Old May 19th, 2007, 06:36 AM   #5
I did uncheck make movie self contained. Process is now about 2 minutes from completion. I will go back and perform it again, making sure.
Old May 19th, 2007, 07:03 AM   #6
Have a look at the file size it should be only a few meg.
Old May 19th, 2007, 07:14 AM   #7
I have double checked that the Make Movie Self Contained us unchecked and QT still wants to re-compress the files. 24 minutes. Whether I choose the sequence from the browser or choose the clips in the timeline and export to QT, resulting processing times are the same.
I must not be seeing something here.
Old May 19th, 2007, 08:09 AM   #8
Is the timeline grey are green.
or
Try just within qucktime, copy paste each clip, save as reference.
