Inside Firestore? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old September 4th, 2006, 03:42 AM   #1
Inside Firestore?
Does anybody know what hdd-s Firetore uses inside? Are those replacable with biggerones? Or is there any firmware limitations to use "thirdparty size" HDD-s?
Frank Hool is offline   Reply With Quote
Old September 5th, 2006, 05:14 AM   #2
Contributor
Hi Frank,
I replaced the original 40GB HDD in my FS-4 with a
HD AT 2.5" 80GB Hitachi Travelstar 5K80
ATA6, 5400rpm, 9.5mm, 8MB Cache
Modell: HTS548080M9AT00
(which was the same brand and type that came with the unit)
And have had no issues.
The FS-4 will format the new HDD via the UTILITIES-FORAMT menu after the new HDD has been installed. Installing a new HDD is not difficult - but of course you will void any warranty by opening the unit.
Daniel Kohl
Frankenstein meets XL1
Daniel Kohl is offline   Reply With Quote
Old September 5th, 2006, 08:10 AM   #3
Thanks, Daniel, for good information. So You new total size 80GB?
Old September 5th, 2006, 08:13 AM   #4
Contributor
Yes, 80GB was working for me.
Check this thread for more (better) info:
http://www.dvinfo.net/conf/showthrea...6&goto=newpost
Cheers
Daniel Kohl
Old September 5th, 2006, 09:09 PM   #5
will they recognize HD that is larger than 80GB?
James Ng is offline   Reply With Quote
Old September 11th, 2006, 05:30 PM   #6
100 GB works fine as well
i almost went for 120 but i the 100 was quite a bit cheaper
Michael Salzlechner
Michael Salzlechner is offline   Reply With Quote
Old September 11th, 2006, 11:34 PM   #7
Michael, what size You had originally?
Old September 12th, 2006, 06:07 AM   #8
40G
i put the 40 into an external USB drive and changed it to a 100
Michael Salzlechner
Old September 12th, 2006, 02:13 PM   #9
Thanks for good info, Michael
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
