FS-4 wont trigger "rec" from HV10? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old October 30th, 2006, 06:56 PM   #1
Hello everyone. My FS-4 can't seem to record HDV with a Canon HV10 using the Canon's "Rec" button.....has anyone else tried this combo and got it to record from the HV10's "rec" button?
~ I can record M2T files if I use "Local" control but I don't want to use it this way- I want to record via the HV10's rec button~
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old October 31st, 2006, 11:12 AM   #2
Focus Enhancements
Do you have a tape in the camera?
Matt McEwen is offline   Reply With Quote
Old October 31st, 2006, 02:29 PM   #3
Matt,
actually no- I was hoping to use it tapelessly- as it works with the DVX100. My guess is that it's not sending the necessary comands via Firewire- does this sound correct?
Can I use a tape with the tape removed and "fool" it- or will the absence of tape material cause this not to work?
www.stevenunez.com
Old October 31st, 2006, 04:26 PM   #4
Focus Enhancements
Hi Steve,
I have not had a HV-10 in our lab for testing yet, but I assume it does not have the DV Control option and does not allow for control of external DV/HDV devices.
Matt
Old October 31st, 2006, 04:27 PM   #5
Focus Enhancements
Sent too soon...
It does not allow control of external DV/HDV devices without a tape inserted.
Matt
Old October 31st, 2006, 04:30 PM   #6
Would a tape with the stock removed work?
(Thanks Matt)
www.stevenunez.com
Old November 1st, 2006, 01:03 PM   #7
Focus Enhancements
Never tried that and am not sure. I would say you should probably check with Canon that it won't damage your camera before you attempt to do this.
Matt
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
